6.348 forged rods?
6.348 forged rods?
i read thru the sticky for specs before posting this. just saying ahead of time. but i just baught a set of NIB C.A.T forged rods off ebay for like 100 bucks. they are .250 longer than stock. can i use these on my stock rebuild (im installing a different cam and a few other things as well. just need some info on the lengths.
I am not an expert but I think rods for a 4" crank are 6.125 and the ones you bought are even longer. You will need a crank and pistons to match your rods. I do not believe that your new rods with work with the factory stuff.
I don't think they will work for aftermarket parts either . If they were advertized as being for chevy LSx engines I would ask them for specifics because I have never heard of rods for these engines in that length , might be false advertising if they did say they would work . Find out and go from there . Good luck
OWN3D BY MY PROF!
That length would be used in a taller deck block or some mix and match combination of parts. Use Deck Height - (Rod Length + 1/2 Stroke) = In and out of the hole distance... Formula to play around with numbers and see what you can do with them if anything. The variables are interchangable using some algebra.
I just looked on C.A.T.'s site, under 3.900, 4.000, and 4.100 cranks they specify 6.348 rods. Even with 3.900 on a 9.240 deck height, math comes to (3.9/2 = 1.95) (1.95 + 6.348 = 8.298) 9.240 - 8.298 = 0.942.
Anyone else think that compression height is a little short? They do say LS1/LS6 and the part numbers on their cranks have "346" in them. My 6.0 has 1.331 and my 383 had 1.445 with .005 milled.
I could be wrong... but they may work with a stroker piston (383/402) with a 6.125 rod and 4" stroke. I could use them... I'll give you your money back! I might steal the stroke from my 383... what is the pin diameter? Please, pm me if intersted... thanks
