fuel pump questions
fuel pump questions
have a few questions my car has been acting kinda funny lately and so i decided to hook up a fuel pressure gauge to it and its running around 58psi at idle but when i get up around 5k it goes down to around 40 psi. its a walbro 255 pump and i decided to pull the filter and its not to bad you can tell its time to change, could a dirty filter cause this or is it the pump ??? Its also running a filter that ive never seen before it has a return line on the side coming from the tank, when i looked up the filter it was off of a 03 vette
Yes, a clogged fuel filter can cause the pressure to lower. This is the least expensive to change first. It should not be that expensive though. Where are you located?
yeah the car been giving me hell starting so i dont think it just losing pressure at wot throttle, i had a new pump overnighted already and just going to install a new one tonight
