It's Pissing me off
Old 08-28-2011, 03:56 PM
Nowhereman's Avatar
Default It's Pissing me off
Guys, I am on my 3rd bulb now.
I have this issue with the driver side running / turn signal.
It works for a day or two, then goes out.
I have cleaned the socket, file boarded the contacts.
What can it be?
I do not want to pop 50 bucks for a damn socket.
Old 08-28-2011, 04:02 PM
babbage1109's Avatar
50 bucks? Autozone. It was like 15. And some crimp fittings. Problem solved. I had to do this a while ago
Old 08-29-2011, 01:19 AM
Nowhereman's Avatar
Same locking design to the housing?
Old 08-29-2011, 05:57 AM
Yeah. It's a 3157 socket. I actually have to go get one today for my pass side water keeps getting in. Just splice it in right and you're good to go
Old 08-29-2011, 08:24 AM
That's MISTER MODERATOR
Paul Bell's Avatar
nowhereman, what year is this Firebird of yours?
Old 08-29-2011, 08:29 AM
LS1powerd's Avatar
I had this same problem, and did the same, problem solved.
Oh, and auto-zone socket are'nt any better.
Old 08-29-2011, 10:02 AM
Nowhereman's Avatar
I have a 2000 WS6 / 6 speeder.
I've done all the no / low cost mods and she has responded nicely.
I have one more for you guys.
If you get your self a pair of duck bill pliers, you can easily snap out all the restrictive finning inside the stock lid.
That and pulling the screen out with a good air filter makes a world of difference.
I have no thoughts of adding a new MAF now.
I also have an SLP exhaust system in her.
IF I want white knuckle acceleration, I jump on my 127 inch Fatboy.
The power in the WS6 is nice now and the mileage is great.
Old 08-29-2011, 11:27 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I've had the Autozone sockets in my car for about two years and have yet to have an issue
Old 08-29-2011, 03:43 PM
Paul Bell's Avatar
The front turn signal bulbs keep their high filament on when not using the turn signals and when the headlights are off. This was GM's bright idea (pun intended) of "daytime running lights". This causes the sockets to get pretty hot. Being in the bottom of the housing, water can get in them which corrodes the contacts. Eventually, the bulbs go out and/or the sockets burn. New bulbs in burned sockets won't last long.
I would suggest you replace the sockets and bulbs with new ones and be generous with some bulb grease. It's not really grease but a di-electric goop that will make the contacts somewhat water protected and also help wick away some of the heat produced.
If you can find bulbs with a "K" in the part number, use them, they're longer lasting krypton bulbs.
The sockets you get at parts stores are the same that GM has made for them.
If you haven't yet chopped out the old sockets, have a look at this:
https://ls1tech.com/forums/13371160-post26.html
Old 08-30-2011, 10:00 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
AutoZone sockets have lasted longer for me than any of the factory units. I think I swapped one over three years ago. At the time, they cost me $7.00 a piece.
Old 08-31-2011, 12:10 AM
I just swapped out my pass side yesterday. Another thing op check your actual housing for the light to make sure there's no cracks where water can get in. Mine had a hairline crack in the face letting water in a shorting the bulb out.
Old 08-31-2011, 08:28 AM
Nowhereman's Avatar
I found a site that sells the sockets for less than 4 bucks.
They also have a line of LED replacements instead of using the bulb routine.
I run this type of LED cluster on my FLSTF and have had zero issues with them.
So, the ole bird is getting upgraded to 3157 type LED clusters with the new sockets.
Old 08-31-2011, 08:31 AM
Nowhereman's Avatar
Thats cool and a clean way to do it.
I will try that route 1st when the sockets arrive.
Thank for the tip.
Quick Reply: It's Pissing me off
