mast black label ls3 heads
Old 08-29-2011, 10:01 PM
2000redcamaro's Avatar
Default mast black label ls3 heads
is anyone on here running the mast heads? i bought some for my 408 build. im hoping that will make some good power. any feed back on these would be great.
Old 08-30-2011, 06:33 PM
Jimbo1367's Avatar
They look like junk. I'll let you know how they work holding my door open. LOL. Heard ALOT of good things about MAST heads.
Old 08-30-2011, 08:07 PM
ULTIMATEORANGESS's Avatar
ive been told MAST is the head to go with.
those castings look beefy.
Old 09-05-2011, 10:49 PM
CAMSTER's Avatar
Default have a set
part #510-307 Large bore ls7 have 274cc intake port volume flows 395 cfm, going on my new N-A 441Ci lsx block bore-out to 4" 185. on E85 with 12.8 comp, engine put together, hope to have it running this month time allowing
https://ls1tech.com/forums/generatio...t-pix-now.html
Old 09-06-2011, 12:29 AM
Restricted User
jalper's Avatar
what is the big difference in the heads, i herd that the ls3 head is a good head but the ex-valve was to small, is there any change in the size compared to stock.
Old 09-08-2011, 09:31 PM
CAMSTER's Avatar
Default I'ts all in the flow....
just compare the numbers, and the C Cs, [intake ports volume] then the deck-or base of the head thickness, there's no comparison ...
Old 10-20-2011, 08:41 AM
Petraszewsky's Avatar
Get these put on yet? I'm wondering how much of a power difference these would be from getting my LS3 heads CNCd. I would be getting the large bore ls3 mast heads if I got them.
Old 10-21-2011, 12:50 PM
dwill73's Avatar
What intake? solid roller setup? I've heard of two motors making 950fwhp N/A with those heads with a solid roller, 14.5 compression, and the Mast intake. Either way they are some awesome heads and you made a very wise choice IMO.
Old 10-21-2011, 12:51 PM
dwill73's Avatar
Originally Posted by camster
just compare the numbers, and the c cs, [intake ports volume] then the deck-or base of the head thickness, there's no comparison ...
exactly
Old 10-22-2011, 09:48 AM
COPO9560's Avatar
Large bore heads require 4.125 inch bore - may as well get MAST's LS7 heads at this point, price nearly the same.
To the OP - great looking heads. What are your goals? I'm interested in how this build turns out. Can you send more details on cam? FAST or LS3 intake?
Old 10-22-2011, 10:34 AM
dwill73's Avatar
X2, Plus the Ls7 is a better port design then the Ls3
Old 10-22-2011, 12:05 PM
hymey's Avatar
I seen the mast LS3 11 deg heads pick up 52 rwhp and 5 mph OUT THE BOX over stock LS3 heads in a camaro, so yeah they work.
Old 10-22-2011, 03:51 PM
bunker's Avatar
the 11* must do it, but i wonder how they compare to GMPP CNC LS3 heads out of the box. compare apples to apples
Old 10-22-2011, 07:50 PM
fatboyzcamaro's Avatar
keep us posted need info like others.
Old 10-23-2011, 02:58 PM
KJS408's Avatar
I'd like to know that as well, the GMPP CNC LS3 heads are what I bought for my 408 build and are half the cost, it would have to blow them out of the water for me to buy the Mast Black Labels.
Old 10-23-2011, 03:20 PM
Great article on LS3 heads....There are many more but this is a good one..
http://hotrod.automotive.com/151810/...est/index.html
Old 10-23-2011, 05:43 PM
flintwrench69's Avatar
Better valve angle, great flow numbers, beefy castings & quality valvetrain components I really dont see how you could go wrong with these. Just about the best LS heads youre gonna find anywhere.
Old 09-11-2012, 03:28 PM
car is finally running now. build went way over what i was wanting to spend. should be dyno'd in the next few days. ill post the sheet. everything i have heard and read about these heads is awesome. im looking for 550rwhp ish N/A for a street car. will spray is it later (kid on the way) thanks for the imput guys
Old 09-11-2012, 05:00 PM
goal is to have a 9 sec street car i can drive anywhere. im using the ls3 intake since mast said there is only a 7hp gain over stock ls3 with the fast 102. the cam is 238/248-650/650-110.
Old 09-11-2012, 05:38 PM
litle88's Avatar
Oh man I'm subscribed bud!
Quick Reply: mast black label ls3 heads
