Possible Cam For A L33
ok so I have a bone stock L33 I picked up with 24k on it.
I'm picking up a used LSXrt intake manifold and I'm wanting to go ahead and do some type of cam.
Now i'm kind of wanting that is still streetable and not strip only.
A buddy offered me his setup he was going to put in his.
What do you guys think?
Cam -
Intake valve lift - .580, degrees of duration 225
Exhaust valve lift - .590, degrees of duration 229
Lobe center 114 + 4 LSA
Push rods -
5/16" x 7.400" hardened
Valve Springs-
Gold Dual Valve Springs, Super 7 Locks, Ti retainers, Seals & .505" Bases (use with stock guides)
Cam -
Push rods -
Valve Springs-
EPS told me to go with a 218/222 cam with around .595 lift on both sides.
If I had 3.42 gears he said I could go with a 222/226 with around .595 lift
So I would look for something around those specs.
what heads are on it ,consider head port flows to pick a good fitting cam with the proper duration splits..comp cams have some good LSr cams for L33s or contact Patrick-G for a custom cam that will make great power for your combo.
OP that 225/229 is on the large side for a 5.3 and I would stay away from that if you want to enjoy driving it. The 218/220 intake duration suggestions above are the max I would recommend.
