Please help. Good local buy on Pro Stars. Will they fit???
Old 08-31-2011, 03:01 PM
moderate Z28's Avatar
Default Please help. Good local buy on Pro Stars. Will they fit???
http://valdosta.craigslist.org/pts/2570652177.html
Will these fit on my 95 Trans Am? Im not worried about grinding calipers or anything a little but is this the right size? The size most people run? Thanks. Will be for the 95 T/A in my sig for the few times I take it to the track.
Old 08-31-2011, 03:20 PM
OIF1VET's Avatar
You need to find out what the backspacing is.. Fronts(15x4) should be 1.75, rears(15x8) 5.5(I believe the Backspace is the same for all 4th Gens, someone correct me if wrong)..
Old 08-31-2011, 03:23 PM
Well he said they came off an 81 Camaro. Just talked to him. I dont think they will work then will they? He said the rears look like about 4" BS but hes going to email me with the measurements. Thanks.
Old 08-31-2011, 03:26 PM
OIF1VET's Avatar
Pretty sure an 81 has different backspacing..
Old 08-31-2011, 04:19 PM
lethal bird's Avatar
They do.
Old 08-31-2011, 08:31 PM
LUNATIK LT1's Avatar
you can fit the rears with 15x10, 7.5 bs / depending on the tire you may need to roll the inner lips of the fender. Is the car lowered at all? 26" tall rear will fit with no problem, just may need some slight BFH work. Stock calipers might/might not have to be beveled. Is the rear end narrowed?
Old 08-31-2011, 09:17 PM
Rears all stock. What would it do if you tried to put on around a 4" BS? Would the wheel stick out or something?
Old 08-31-2011, 09:58 PM
bigj2717's Avatar
Yeah they will stick out past the fender
Old 09-01-2011, 12:22 AM
This man speaks truff. The look like do-do.
Old 09-01-2011, 12:29 AM
lemons12's Avatar
Stick out and look dumb. stock 3rd gen wheels do the same thing.
PASS
Old 09-01-2011, 12:25 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
15x4s with 2.25 backspacing fit on the front as well, with the usual grinding
