Ls6 intake or ls2 intake
Old 08-31-2011, 05:42 PM
lsxc4vette's Avatar
Default Ls6 intake or ls2 intake
I want to get an LS6 intake for my ls1 motor.Does'nt have the ls6 intake.But then I was looking at the LS2 intakes.But I was reading that the Ls6 intake might be better to go with.Anybody have good results with the LS2 intake.Right know I have the 241 heads and only plan on doing a cam change.Maybe get the 241 heads worked on(valve job,port work).Or maybe get a pair of used 243 heads.Which intake did or would you guys or gals go with. thanks
Old 08-31-2011, 05:45 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
If you can get your hands on an LS6 intake I would definitely grab it up. They tend to make a little better power, but if you get an LS2 intake you would have to get a throttle body because they are 90mm. The stock throttle body will fit on the LS6 intake no problem.
Old 08-31-2011, 05:53 PM
Floorman279's Avatar
^^^^ditto.
Old 08-31-2011, 06:26 PM
lsxc4vette's Avatar
Thats what I figured.I seen some used LS2 intakes and was just wondering if it would be a bad move instead of the ls6 intake. thanks
Old 08-31-2011, 10:01 PM
Matt 00' T/A's Avatar
Originally Posted by Floorman279
^^^^ditto.
++1 I run the LS6 intake and have to say for the money is well worth it.
Old 08-31-2011, 10:34 PM
01cherryreds10's Avatar
From what I've read stock vs stock an LS6 is better. A ported LS2 would be better than a stock LS6, but for the price of switching over to an LS2 plus porting costs, a FAST would trump all.
Old 09-01-2011, 09:58 AM
headed-ws6's Avatar
Im getting an ls2 for now ill be buying a 102mm tb and then when i get the money together buy a ported fast 102 . Ls2 can be had for cheap.... I wouldnt waste money porting it but will be a great stepping stone on my way to the fast intake.
Old 09-02-2011, 11:46 PM
01ssreda4's Avatar
Moving to external.........
Old 09-03-2011, 07:24 AM
bottlefed01z28's Avatar
From what I've heard the ls2 doesn't flow as well as the ls6 also I've heard of problems with the ls2 like cracking and what not
Old 09-11-2011, 06:42 PM
TKeeby79's Avatar
I am building my LS conversion and this was a question I needed answered, Thanks.
