What 92mm throttle body for fast 102
ive seen some posts where they are not fitting correctly because there is not enough material at the bottom of the throttle body?? has anyone used a 92mm nick williams cable driven tb on a fast 102???????????? i may have bought the nick williams too quickly.
It should work. I've seen a guy at a show with a 92mm on a 102mm. Granted I don't know if he had problems installing it, but from my knowledge it should bolt right up. I could see where some other not so reputable TB's may not, but I would assume a FAST and NW would. The guys who's didn't might have taken the cheap route and located a different brand online...idk
https://ls1tech.com/forums/generatio...ttle-body.html
http://www.thunderracing.com/shop-by...-Body_649.html
That is exactly what mine looked like... I am sure you could get a piece of aluminum plate and cut is out as an adapter....OR Weld and aluminum bead across the bottom and mill it flat again....
I am sure you can "make" it work just decide which way is easiest...
Call Vengance and see how they are getting it to work.. I just don't see it there are only 4 screw...No way to really change the install...
Maybe they are oblonging the mounting hole??
Matt
Matt
oblonging the holes would throw the vmax velocity ring and the tb off.... i did knowtice the fast 92mm has a lip at the bottom unlike the nick williams as seen in said pic below... shame tho.. id 100% rather have a nw than a fast tb. I have heard of some failures.
