Fast 102 What Throttle body
I have a fast 102. Tried to install nw 92mm t-body, but it just barely misses the seal on the 102. I was under the impression they fit together since the fast 92 is an option when ordering. Need some insight.
Nope, the 92mm TB's don't seal. We can get you a PTM, Nick Williams, or FAST 102mm throttle bodies. Just depends if you have a preference or what your budget is. Let me know if you need one and we'll get you fixed up!
Jon
Jon
Yup I was under the impression that they did bolt right up?
I had to send my 95PTM back to TSP cause it missed the Seal also so don't understand how some of you believe that they do fit, cause they don't!!! have had to go with the PTM 102
A FAST 92 should fit according to FAST's application chart.
http://www.fuelairspark.com/Catalogs...ow%20Chart.pdf
Last edited by BlackBADaSS02; 10-15-2010 at 08:15 AM. Reason: Fixed for ls1 1990 VN
That's a myth about low end loss. No loss with a 102 TB just not a lot of gain over a smaller one. Maybe a 96 gives you the same results as a 102 but a 102 won't be less. I picked up low end torque with a 102. That being said, the 96 is not a mistake. It's probably more cost effective and a little easier to tune..
Maybe the Fast T/Bs all fit, i wouldn't have a clue, but would assume Fast would make sure they do.
What i was trying to use was a PTM 95 & that certainly didn't fit, not sure about the N/W T/Bs.
Why was i trying a 95 T/B? Cause i like others had read that you lose low end torque with the 102 T/B, i road race and didn't want that or idle/low rev issues, I have now read different!
I ended with no choice but to use the 102 PTM.
A 92 should fit according to FAST's application chart.
A Fast 92 will fit, YES. No where does it say any other Brand of T/B will, even though another Brand 92 could. Others that read these threads need correct information, not induendo, if i had read correct information originally i wouldn't have ended up with the wrong T/B that wouldn't fit the Fast 102.
