How do i get this clamp off?
Old 09-05-2011, 11:39 AM
Perry125's Avatar
Default How do i get this clamp off?
The nut seems to be part of the rest of the clamp, and the bolt head is an oval shape.
Old 09-05-2011, 12:00 PM
Darkman's Avatar
You might try two nuts on the exposed threads - lock them together and use them to turn it clockwise.
Old 09-05-2011, 12:05 PM
JaYZeig's Avatar
i would try spraying some penetrating oil on them threads and nut and try breaking that nut loose...odds are that it most likley will break, and i would def. have a spare set aside. inless your swapping out the exhast.
Old 09-05-2011, 12:38 PM
93batmobile's Avatar
is the nut welded on? if so, time to break out the sawzall
Old 09-05-2011, 12:44 PM
got milk??'s Avatar
Hack it off and get a new clamp.
Old 09-05-2011, 01:12 PM
99Bluz28's Avatar
Use a dremel tool with a reenforced cutoff wheel and just take you time and cut through the band.
Old 09-05-2011, 01:20 PM
TImmy_Jones's Avatar
^^Yeah man, is that the clamp on the I pipe for the exhaust? I had to cut the one on my 98 to get off - the one on my 02 just came right out nice and easy. I would cut at that middle piece with a sawzall or dremel.
DO NOT FORGET EYE PROTECTION WHEN WORKING UNDER A VEHICLE - one little metal scrap and it is over.
Old 09-05-2011, 02:57 PM
Perry125's Avatar
I can't turn the bolt because the head is oval shaped.
My harbor freight dremel blows so i just went and got a harbor freight recip saw too cut the bolt apparatus off.
I'm putting a catback on, do you think I am supposed to reuse this clamp?
Thanks
Old 09-05-2011, 03:28 PM
That's MISTER MODERATOR
Paul Bell's Avatar
That nut is supposed to turn but it looks like this one won't.
Using a six point deep socket and a breaker bar, give it a nice big turn. It'll break so be ready for The Big Snap and don't get hurt.
A twelve point socket will just round the nut so:
Old 09-05-2011, 04:31 PM
TheSilverOne's Avatar
Get a new clamp and use some quality power tools.
Old 09-05-2011, 08:10 PM
WKF
WKF's Avatar
Sawzall or the ever trusty dremel !!
Old 09-05-2011, 11:42 PM
thegodfather899's Avatar
saw it off...that one looks nasty
Old 09-07-2011, 09:17 AM
Z28_Driver's Avatar
A cutoff wheel on the center of the bolt where it goes through the clamp should take care of it.
Old 09-07-2011, 10:32 AM
1badWS6's Avatar
Bust out the sawzall!!!
