whats the trick to getting this bolt out? for spring change
Loosen the 2 nuts that secure the brake booster to the firewall- 13mm or 15mm (?) and GENTLY pull the brake reservoir away from the firewall and to the side (as req'd). Move it just enough to access these #50 Torx bolts. The rigid brake lines have some give but use common sense/care when "flexing" them out of the way...
You're going to pull the Master Cylinder away from the booster when you loosen the 2 15mm bolts...and yes 3rd gen's have struts. 4th gens have a coil over shock
Just putting this here for others, as it's related & also covers this issue as well.
http://www.streetfire.net/video/Koni...all_688318.htm
ive seen that and to me ...no it does not cover the issue im asking about.
If you look at it he loosens the master cylinder but in no way enough to allow the socket to rise with the bolt once it starts coming out...then it just skips to both bolts out and he says he used a pair of vise grips....lol...ok??!...would have been nice to see.
anyone know how long those bolts are?
You need to do this ^^^^ Once you have loosened the two nuts that hold the abs block, you can gently move the block, lines and reservoir over enough to get to the bolt.
Besides, you still need to move the master cylinder to get a 16mm socket in there.
I wish that would work but I just bought some grade 8 7/16" bolts to replace them and they wouldn't fit. Even though the thread count is the same the width of the threads is just enough not to be able to thread into the hole.
A 16mm open/box slides underneath the MC.
Don't need to purchase anything. Use the Torx on the passenger side and the hex on the driver's side.
