Is it possible to just repair my headers?
Old 09-06-2011, 06:50 PM
Slash8915's Avatar
Default Is it possible to just repair my headers?
I had my ORY replaced today because my old one literally fell apart. Well after the install, we started up the car to check for exhaust leaks. Under the hood, we saw some small flames shooting out of what LOOKED like one of the spark plug holes on the passenger side. We checked it out and it was as tight as can be. We looked some more and sure enough, the flames were coming from the bottom of one of the tubes on my header.
I'm guessing it's cracked. Is there anyone or any WAY it can just be welded up or repaired instead of having to buy all new headers?
Old 09-06-2011, 07:55 PM
TexasVortexx's Avatar
Sure, though it will require to be removed from the car. I would weld each tube up in the same manner as the leaking one.
Old 09-06-2011, 08:10 PM
Bad Chad's Avatar
If it is rusted that bad I would just buy new headers and be done with it. Its going to be hard to celan and weld the thin metal without it falling apart
Old 09-06-2011, 08:18 PM
Slash8915's Avatar
****, that's true. Damn it, I didn't want to spend this much money. Local shop quoted me almost $600 to replace the headers JUST in labor.
Old 09-06-2011, 09:10 PM
NemeSS's Avatar
A welder with the correct tools prolly not gonna charge cheep to repair. Prolly make more sense to get new headers. Ebay lt are not so bad.in price or quality
Old 09-06-2011, 09:51 PM
Cam72aro's Avatar
If they are rusted then I agree with Chad, better off replacing them because you can't weld thin, rusted material. If its just a crack, which is highly unlikely, then it can be welded, if thats all it is.
Old 09-06-2011, 09:55 PM
msydow's Avatar
buy cheap ones and have them installed, or buy better ones and do it yourself.
just my .02
Old 09-06-2011, 10:12 PM
whatsa347's Avatar
http://houston.craigslist.org/pts/2582298032.html
Check that out, I heard the BBK's were a nice piece and he's willing to negotiate. What brand did you have that rusted that bad?
Old 09-06-2011, 10:21 PM
Slash8915's Avatar
I already called him. He won't separate. So unless someone here wants a y-pipe, I'm SOL with that deal. I have Hookers.
Old 09-06-2011, 10:49 PM
s-10ls1's Avatar
Can you get a pic of the header where it's messed up?
Old 09-06-2011, 10:52 PM
lemons12's Avatar
You can do headers with simple tools in about 4 hours on the ground.
Or pay a the member 200$ or something to do it.600$ is stupid.
Slash8915's Avatar
Definitely not. I can't even see it. I just have a general idea of where it is.
Old 09-07-2011, 09:08 AM
SSHAWK's Avatar
x10 lol
$200 is avg price to do the swap...
Old 09-07-2011, 11:45 AM
v8sten's Avatar
slash ill replace them for you. ill do it for $200. welding is just a temporary fix it will crack again. been there done that. im close to you also.
Old 09-07-2011, 02:07 PM
carlos sauceda's Avatar
I got charged 135$ if i remember correctly from a local shop
Old 09-07-2011, 06:31 PM
TruBloodTransAm's Avatar
It's not that bad of an install. Just get some friends together to help.
Old 09-15-2011, 08:16 PM
Slash8915's Avatar
Well... Here was the problem... Miraculously I didn't burn a valve.
Old 09-15-2011, 08:17 PM
Are those Kooks? Are they under warranty?
Old 09-15-2011, 08:20 PM
Slash8915's Avatar
Hookers, and I doubt it. I replaced them with stainless steel Kooks.
