Kevin@Vengeance
09-09-2011, 03:16 PM
Vengeance Racing Budget Cam Kit:
-Vengeance Racing Custom Camshaft of your choice
-TEA Dual Gold Spring Kit with Tool Steel Retainers good to .660 lift
-Trickflow 7.400 Pushrods
$649!!!!!!http://images.ibsrv.net/ibsrv/res/src:ls1tech.com/get/forums/images/smilies/LS1Tech/gr_eek2.gif
Vengeance Racing Cam Kit Plus
-Vengeace Racing Custom Camshaft of your choice
-TEA Dual Gold Springs with Ti retainers good to .660 lift
-Trickflow 7.400 pushrods
-Meiling High Volume Oil Pump
-Comp Trunion Kit for stock rockers
-Ktech C5R Timing Chain
-ARP Cam bolts
-GM Crank Bolt
-GM front cover gasket
-GM front cover seal
-GM waterpump gaskets
$1299!!!!http://images.ibsrv.net/ibsrv/res/src:ls1tech.com/get/forums/images/smilies/LS1Tech/gr_wink.gif
Vengeance Racing Budget Heads/Cam Kit
-TEA/Trickflow 220cc As-Cast Cylinder Heads loaded with TEA Dual Gold Springs with Tool Steel Retainers
-GM MLS 5.7 Head Gasket
-GM Head Bolts
-Trickflow 7.500 Pushrods
-GM crankbolt
-GM Watepump gaskets
$2299!!!!:headbang:
Vengeace Racing All Out Heads/Cam Kit
-TEA/Trickflow 215cc or 225cc CNC Cylinder Heads load with TEA Dual Gold Springs with Ti retainers good to .660 lift
-Milled to desired compression
-GM MLS Head Gaskets
-ARP Head Bolts
-Trickflow 7.500 pushrods
-Meiling Hi Volume Oil Pump
-Ktech C5R timing chain
-Comp Trunion kit for stock rockers
-GM Crank Bolt
-ARP cam bolts
-GM water pump gaskets
$3599!!!!http://images.ibsrv.net/ibsrv/res/src:ls1tech.com/get/forums/images/smilies2/naughty.gif
-ARP Cam bolts
-GM Crank Bolt
-GM Head Bolts
-GM crankbolt
$2299!!!!:headbang:
-ARP Head Bolts
-GM Crank Bolt
-ARP cam bolts
