stock (spray/cam only) lq4 in 1955 chevy
i've been putting together a project car and taking it to the local track. its a 1955 210 post (2door). engine is a stock iron block lq4 6.0 ls. has a comp xr275hr cam (222/224 .566/.568 112) and headers. everything else is stock 40k+ miles. trans. is th/350 and 10" ptc convertor (around 3000 stall). rearend is a stock 8.5 10 bolt with factory 3.42 gears from a 78 camaro. i swapped in a minispool. also have full 2.5" exhaust with cutouts. i'm running a 255lph walboro inline fuel pump. and have an nos drykit off of an lt1 with built in regulator to spike fuel psi. havent seen anyone run this kit on an ls1 before. i converted a purge kit into a second stage to split the n2o up, due to traction. rear tires are m/t slicks 28x9 on 7" steel rallys. only traction device is some old slapper bars that were free.
have a friend using H/P tuners to tune on the car.
really having a blast with the car and steadily improving the e.t.s. cooler weather should help.
took it back to the track this past fri. and had a new best e.t. of 6.40@104.9 with a 1.42 60ft. which was not a perfect run so, it should go 6.3s.
doing a disc brake upgrade for the front soon, so hopefully be able to take it to a 1/4 mile track and be able to get stopped. lol
looking to eventually go mid 6.3s or 9.9s in the 1/4. not far away at all. if i could leave on everything and hook, it would be there.
http://www.youtube.com/watch?v=WSpKQ...&feature=feedf
video from a month ago. primered the car black since then. in this video car was on 26x8.5 slicks and had to leave VERY easy. ran 6.8 on that pass.
i'd hafta have a laptop and set the timing for motor passes.
BTW, cool skylark!
