Which heads to use?
Old 09-12-2011, 04:45 PM
hartman's Avatar
Default Which heads to use?
Alright not sure if you guys seen my thread in which i was trying to figure out what heads i have but i finally got them flowed and now i gotta decide which set to use. I currently have 241 one heads with stock springs and will probably be going with a T2 cam. So which ones?
243 heads with comp springs good to .600 lift or:
Think there patriots:
227cc intake
85cc exhaust
2.02 intake valves
1.57 exhaust
65cc chamber
10 degree locks
145lbs @1.785
365lbs @1.185
Intake cfm Exhaust cfm
.100 69 49
.200 140 106
.300 200 144
.400 251 179
.500 281 200
.600 266? (seems odd) 213
I will have the rest of the specs tomorrow when i pick up the heads. But im not sure which are better as i do not know what the specs are on a 243 head.
Old 09-12-2011, 04:48 PM
PREDATOR-Z's Avatar
The Patriots are ported so theoretically, they should be better than stock 243s.
Old 09-12-2011, 08:45 PM
hartman's Avatar
What are the specs on stock 243's?
Old 09-13-2011, 06:55 AM
supersick99z's Avatar
Patriots over stock 243 hands down
Old 09-13-2011, 10:22 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Don't forget the PRC LS6 heads. They are priced very comparable, but from there you'll find some big differences. In a perfect world you could hold & flow both brands side by side. With the PRC LS6 heads we fully cnc port the heads & do a cnc valve job with a newen seat & guide machine. From there we hand blend every set of heads & then mill the cylinder heads specifically for the customers combination & camshaft for no additional charge.
Every set of cylinder heads are fully pressure checked including the ports to make 1000% sure the valve jobs seal perfectly for our customers!
It may take us a little extra time to build the PRC cylinder head, but the attention to detail pays off in the long run for our customers!
http://www.texas-speed.com/p-1391-pr...ted-heads.aspx
http://www.texas-speed.com/p-4-prc-s...ted-heads.aspx
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 09-13-2011, 10:24 AM
Oh & the PRC heads are on special right now & in stock with milling for Torquer camshafts.
__________________
Jason
2005 Twin Turbo C6
Old 09-13-2011, 12:16 PM
hartman's Avatar
Would definatly be interested but i already have both of these sets of heads because they came with the car.
Old 09-13-2011, 09:40 PM
hartman's Avatar
added specs of the heads
Old 09-13-2011, 10:13 PM
A.R. Shale Targa's Avatar
If you click on the Advanced Inductions link on the right and navigate through
the stock 243s are around 260/190 cfm stock..but they show all liftpoints.
