Ditch Maggie and go H/C?
Old 09-13-2011, 08:11 PM
TPIMarow6.6's Avatar
Default Ditch Maggie and go H/C?
I currently have an LS2 with older patriot 5.3 heads, Speed Inc SI5 cam 231/237 589/595 and a Maggie 112 with 90mm snout and FAST 90MM TB.
I am wondering if it is worth keeping the maggie on the car or should i go with a bigger set of heads and cam?
Realistically im guessing i should make somewhere around 500-550whp, maybe more and i see guys making around 500whp with a nice set of heads and bigger cam. And see good numbers with l92/l76 setups.
Any info would be appreciated, The engine is in a 71 Vega, 6-speed. I plan on doing alot of drag racing but will be street driving the car as well.
Old 09-30-2011, 10:45 AM
FloydSummerOf68's Avatar
I'm not sure what the goal is here.
I'd sell the maggie for a centrifugal blower and easily eclipse 600rwhp.
A max effort heads/cam LS2 will see 515-525rwhp through a 6 speed.
Old 09-30-2011, 02:17 PM
99Bluz28's Avatar
What the lsa on the cam, 114, 115? You want a wider lsa to minimize boost bleed off.
Old 09-30-2011, 06:26 PM
331billet's Avatar
A H/C/I car may hit close to the same rwhp that a maggie car does but never the rwtq that a maggie does. At least I have never seen one on 11:1CR.
My 2006 GTO stock LS2 M6 with Kooks 1 7/8" LT's with 3" spintech stainless steel exhaust, chrome Maggie TVS 2300 running 8 1/2 lbs put down 540/550 to the tire.
Why not just change the pulley and add more boost.
Old 10-02-2011, 09:23 AM
Ragtop 99's Avatar
If you're bracket racing for points and want 500 RWHP, I'd sell the maggie and get a good set of heads. It's easier to be consistent NA than with a maggie.
If you're just into TNT and having fun, I'd leave the car alone or pulley down if you want more power.
Old 10-07-2011, 05:11 PM
-TheBandit-'s Avatar
Originally Posted by 331billet
My 2006 GTO stock LS2 M6 with ... chrome Maggie TVS 2300 running 8 1/2 lbs put down 540/550 to the tire.
I'm glad you got the chrome one. There's no way you could have put down those numbers with a plain finish.
Old 10-07-2011, 06:59 PM
COPO9560's Avatar
Why not keep the Maggie and add H/C - best of both worlds.
Old 10-07-2011, 07:09 PM
kinglt-1's Avatar
This!!
Quick Reply: Ditch Maggie and go H/C?
