View Poll Results: Better traction with lca relocation brackets?
I got much better traction/60ft after installing lca relocation brackets!
17
60.71%
They helped with traction a little
10
35.71%
I did not notice a difference in traction :/
1
3.57%
My traction got worse after install lca relo brackets
0
0%
Voters: 28. You may not vote on this poll
People with lca's/lca relocation brackets come in!
Old 09-14-2011, 01:52 AM
Restricted User
z99ls1's Avatar
Default People with lca's/lca relocation brackets come in!
Soo after searching I have seen alot of threads where people got better traction from there lca relocation brackets, but in a few I seen where somebody took thers off because they thought they made it worse and one that didn't seem to gain much. So those of you out there post up your before and after results plz! Did the lca relocation brackets help you hook? What gains in 60 fts did you get? I will also include a poll
Old 09-14-2011, 03:51 AM
whytryz28's Avatar
They improved traction for me at the track for sure, got rid of wheel hop. Im lowered and it worked.
Old 09-14-2011, 04:00 AM
Restricted User
z99ls1's Avatar
Did you get a better 60ft? Did you have a traction problem before you put them on and did it help traction?
Old 09-15-2011, 10:20 AM
Restricted User
z99ls1's Avatar
Come on people. I know theres got to be more people out there with lca's!
Old 09-15-2011, 11:57 AM
COSPEED's Avatar
I've done fine without relocation brackets. I'm lowered 1" and run non-adjustable lcas with a Moser 12 bolt running 315s.
You can go with any of these.
http://www.byunspeed.com/index.php?c...&filter_id=484
Old 09-15-2011, 01:33 PM
UMI Performance's Avatar
Originally Posted by BYUNSPEED
Customer already has UMI, nice try
Old 09-15-2011, 01:35 PM
COSPEED's Avatar
Thumbs up
That is fine. But it's still good info on the entire post for future readers.
Old 09-15-2011, 09:05 PM
VinR1's Avatar
Ive got both - SLP boxed/poly LCA and UMI brackets. Honestly I did em b/c I lowered my car 2" and thought the geometry needed correcting... after, I notice the rear tires certainly plant harder and the rear doesnt kick out nearly as much as it used to
Old 09-16-2011, 12:06 AM
01ssreda4's Avatar
Mine didn't help much but I was greatly over-powering the tires. Now with better tires my car hooks. Do the relo brackets help that? Probably so. Meaning same track, same day, I'm cutting better 60fts then other f-bodies that have more tire and more power. So I must be doing something right.
Old 09-16-2011, 01:59 AM
82cetuner's Avatar
so where would the optimal place to pute LCAs on a relocation bracket be for good traction on a lowered vehicle? say with strano springs
Old 09-16-2011, 03:11 AM
Restricted User
z99ls1's Avatar
Is your car lowered much?
Old 09-16-2011, 07:52 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Every car will generally want something different depending on quite a few variables such as track condition, what kind of tires your using, how much power your are making, what kind of transmission you have, the ride height of the car, and others. I try to get people to play with the adjustment on the relocation bracket that way they can find out what their car reall wants.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 09-16-2011, 03:03 PM
john shea's Avatar
I've had them on for many years and think they have deteriorated.
I did have my best 60 with them but it was not dramatic maybe .05 better
on the average.
Old 09-16-2011, 04:00 PM
01ssreda4's Avatar
Its lowered with the SLP Eibachs/Bilstein combo that came on the car from SLP as their suspension upgrade.
Old 09-16-2011, 04:50 PM
boostednismo's Avatar
I don't remember if the LCA's helped my 60ft or not. But the relocation brackets made my 60' more consistent. Before i had a best of 1.62 but it would vary from 1.62-1.68. Last time at the track with the relo brackets it was a more consistent 1.61-1.62.
Old 09-16-2011, 05:22 PM
Restricted User
z99ls1's Avatar
Are you lowered also ?
Old 09-16-2011, 05:38 PM
No, unfortunately I'm still stock height.
Old 09-16-2011, 05:42 PM
AndyIsLost's Avatar
Lowered my 60fts 0.2, stock ride height.
Old 09-16-2011, 05:49 PM
Restricted User
z99ls1's Avatar
2 tenths? Thats what I like to hear!
Old 09-17-2011, 01:13 PM
meine96ws6's Avatar
lowered on "eibachs"... the car launches straighter and no more wheel hop.. i say go for it because its not an expensive mod..
and i went adj because i wanted to perfectly center the rear tire.. here is how low i sit..
Quick Reply: People with lca's/lca relocation brackets come in!
