Which drag bar?
Which drag bar?
Im trying to decide on who's drag bar to run.
UMI was fast to answer my questions, but I need a measurement to see if there mounts that bolt to the rear end will work for my 8.8 rear (since the tubes have a step in them from being slid together
BMRs I think Ill have the same issue with
WOLFE's single Bar looks like a great option for how my axle tubes are because the mounts weld to the outside of the tube but is there a down fall to this design?
LS1Tech Premium Sponsor
It wouldn't be anything for us to alter our current ARB to work with what you are doing. Our ARB with weld on chassis tabs is $425 shipped and then you will need our sway bar stands to weld onto the housing which is an additional $30 dollars.
We do have a full bolt on version for $450 shipped.
