LS3 418 Stroker
LS3 418 Stroker
Hey got my 418 LS3 getting shipped to me in a couple days just trying to tie up the loose ends before it goes in. From what iv read 42 lb injectors are the size i need is that correct? Its going in a 98 F body. Let me know what you guys think and if you know any websites that have what i need. Thanks
Its got the fast 102 intake and tb, monster stage 2 clutch, 9 in rear, 1 7/8 long tubes 237cc PRC ported heads, LS7S Camshaft: 242/250 .614'/.614' (with 1.7:1 Rocker Ratio), 114 LSA..4:10 gears want to get as close to 550hp as i can....so you think 52 lb injectors should do the trick?
