Another Cobra vs LS1 ......
And yes he did come around after the 1/4 mile....
Power to weight ratio works better the lower the speed (someone correct me if I'm wrong here LOL) so I doubt that's it. More aerodynamic doesn't work either since both car and truck only managed a 100mph trap speed. Maybe a slow shifter in the Cobra? I don't have audio at work so I can't tell. Who knows, Mustangs suck!
No not really, my truck cuts 2.0's and he was right there for the first 40 ft. or so until my truck started pulling...I don't see to many street tire mustangs/ cobras getting much better then 2.0 on average...sometimes you will see a 1.9 if the track is right...
I like watching that Ram run over cars.
The 4l60e in stock form does not like to shift past 6200rpms...it looses pressure, pretty simple fix, but the trans needs to be pulled for the correct modifications to allow it to **** at 6400 where I have it set at.
I don't know why you are getting so confused with why the ram pulled so hard in the mid range.....Its a bigger motor with more power .....the 4.6 cobra motor has less tq everywhere.....then on the top end you are comparing 4400lbs automatic brick vs a 5 speed 3400lb car that slices through the air....
next time you are driving 70 mph stick your fat head out the window and try to notice whether or not if the air pushes your head backwards.....then try it at 100mph and tell me that my truck is not affected by areodynamics....
Here is a 20 roll...the Camera guy heard my truck hit the limiter on the 2-3 shift...he thought It blew...LOL....
http://www.youtube.com/watch?v=4jHtgalF4yQ
