Floating rear end
Floating rear end
So I'm goin to check everything but can I have any insights as to why this rear ends? I have non adjustable lca's, eibach ProKit, new Bilstein shocks, dual adjustable phb. I'm gonna put on relocation brackets this afternoon and I will double check everything.
An example: when I hit a bump I can feel the rear bouncing around more than it is supposed to, any help would be awesome!!
More so side to side, when I hit bumps it feels like it moves back and forth and when sharp turning it feels like it drifts out a bit the comes back when I straighten out. Even my gf noticed that yesterday. And the brand new rear shocks were put in a year ago
LS1Tech Premium Sponsor
Pretty typical, actually. The stock panhard is comically flexible...same with the torque arm and LCAs.
Well the relocation brackets are on, car feels better over bumps after removing the LCA at the rear end and cleaning it off then reinstalling it, we also check the coils to make sure they are on and they are . . . . still the same side to side effect, but it makes less noise and moves a bit less. i drove my buddies lowered SS (same coils as mine) and his rear end does not do this next we'll check the point where the shock is held in on the interior of the car and after that if it's still makin noise it'll go to a shop and they can fix it
I've had two 98 LS1's - both with mostly stock suspension.
Both of the rear-ends felt floaty in the corners.
I'm paying close attention as I'd like to know what works for you. I'm personally hoping it's stock blown shocks.
