High HP guys with 4L80's come help me out!!!
Location: Home town Clive,IA current town FORT BENNING GEORGIA
Trying to figure out what i want to do with my transmission. Car is a 6 speed right now but if i'm going to make big power (over 800rwhp) and track it, a automatic just makes sense. Leaning more towards a 4L80E now because i WILL interstate travel and don't feel like running a super low gear with a tall tire (like zombie was doing). So basically i'm curious about the guys running 4L80's. What company did you go with? How much did you pay? How much power are you running? What stall you running, etc. Car is a 402 aluminum block with a T6 GT91 going into it. Thanks for the help on this guys
I'm running a "level5" 4l80e from FLT with a 3600 billet converter from Circle D. So far, so good...but I've not even really hammered into it yet....only have about 500 miles on the car, and a new rear end, rims and tires going on soon. If I had it to do over, I would at least investigate a 6l80e...although I'm not sure how big the 6l80e is compared to a 4l80e.
One thing I will say, is that you need to choose your rear-gear ratio carefully for what you intend to do with the car. 4.10 gears can get annoying fast on the highway with a 4-speed auto....something that t56 guys don't have to worry about. Since my 4:10 rear has developed issues, I'm building a new rear with 3:73s that should make it just about right for me.
I have helped many, many guys with their decision over the years. In the long run a 4l80e just makes the most sesne. They are based on the TH400 which will handle 800 hp with just a handful of modifications in the right hands.
In the past, I have used John Spears harnesses, but they aren't needed as you may know. That in and of itself cuts some $300 out of the conversion. You'll need a good shifter, I have always used the B&M Pro Ratchet in my clients cars and have not had any complaints or concerns. I've always swapped pedals myself, so there is a bit of wiring to manage there. Also, I fabbed a tunnel plate out of .130" aluminum plate using the shifter boot plate as a template. And the I made a reinforced mounting plate out of 1/4" aluminum plate so that there will be zero issues with the shifter for years to come.
The driveshaft, flexplate, crossmember and floor tunnel will all need to be replaced or massaged. I always install a B&M Super Cooler with braided line and A/N fitting when i do these conversions. I've been doing them for nearly 6 years now, don't hesitate to give me a call if you guys would loke some advice or have detailed questions.
Indeed, a 4l80e is the best all around choice for anyone who wants to preserve overdrive in their street machine.
g
g
I had the same guy who built mighty mouses 4l80e build mine since he also mildly built it with clutches and a mvb before.
Mine has a billet input shaft, billet output shaft, billet rollerized foward hub, straight cut gears, biggest thickest heaviest duty clutch pack made, 34 element sprag, jakes performance manual valve body with pro tree trans brake that I had my builder modify to use a vaccum pump that uses the motors vaccum to control line pressure to make it more of a street friendly set-up. I use a B&M quicksilver shifter with a b&m t handle **** with push button for my 2 step and transbrake. I also have a FTI billet 9.5" lock up 3800 stall convertor. I'm using the BMR tubular crossmember, and a steel driveshaft with 1350 u-joints and a TCI flexplate. Also using a B&M 28k tranny cooler with t-stat control and fan.
Stock 4L80E here
They're stupid strong from the factory. Upgrade if you want, IMHO its cheaper to just replace the damn thing IF you ever break it
And because I know its coming, no you dont have to get a 4L80E that was originally from a LSx truck. The older 90's SBC 4L80Es are just as strong. $200 for a trans that will survive 700tq for atleast a season? Yes please
If you want to go fast, you will put an 80 in it over a 6 speed.
You can spend as much as you want on one, there are some big dollar set ups available. I have one that is more budget minded & so far it kicks ***.
You can modify your T56 crossmember to make it work with the 80e, so you can save some money there, you can also run a 4l80e with jake's dual feed direct band upgrade, and shift kit and it should handle 400-500rwhp. Add clutches and good steels and I could see it taking 500-550rwhp all day long. Anything above that I'd go with a with some internal upgrades although there are others out there making 600rwhp or more with good clutches, shift kit, and good tranny coolers.
Really it's all about keeping the fluid cool. Keep the fluid cool and it will live. Now that doesn't mean it will take 1000rwhp reliably for years to come, but I can see a stock 80e with a good converter, cooler, jakes dual feed circuit and valve body living behind a 400-600rwhp reliably for a good while.
It will interesting to see how long that unit will last cam72aro as I smoked the foward band in mine with 600rwhp.
amen brother. I like to see this with a stock unit.
Stock 4L80E here
