who knows how to bypass the security/key problem
But this only works if its the switch going bad.
http://www.ls1.com/forums/f6/how-byp...ur-vats-61262/
bypass chip on the key
go to your chevy dealer find out what number your key is (each key has a different chip, each chip has a different ohm resistance). Once you have that number you should be able to find out what resistance it is. Go to Radioshack buy yourself some resistors that add up to your key's ohm resistance. Sadder them together ( i spent $2). Look under your steering column and there should be two white wires wrapped in a orange cover. Clip them and connect one end of the resistors to one wire the other end to the other wire. (make sure its the wires leaving the steering column.) then it should work. The computer now thinks the key is giving the correct signal. security is out the window though. But as long as you have the alarm you should be fine.
