Which line off the radiator goes to cooler?
I've been meaning to ask this for a while. I've heard conflicting views on which is the most efficient. With my SSRA, I have my B&M cooler installed in the passengar side service area (cut hole in panel). Currently it's hooked to the bottom line from the radiator. Is that wrong? If so, is it even serving a purpose? TIA
LS1Tech Administrator
Received 1,493 Likes
The top line off the radiator is the fluid return line (going out of the cooler and back into the trans). I found this out the hard way when I blew a cooler hose off last month......
Originally Posted by celerityZ
So it's supposed to be cooled on the way back to the transmission? Is the way I have it now totally pointless?
Out of the transmission---> Into the stock cooler---> Out of the stock cooler---> Into the aftermarket cooler---> Out of the aftermarket cooler---> Back into the transmission.
That setup will give you the best cooling possibile. How you have it now is not "pointless", but if you have it going into your aftermarket cooler first and then into the stock cooler, you're not getting as much cooling as you could be. The radiator ends up heating the fluid back up some on the way through....
