Cam swap disaster
Cam swap disaster
so im wondering how much i just screwed myself over...in the middle of swapping my cam, i dropped a !@#$%^& bolt down in the pickup tube coming out of the oil pan....now what...im struggling to find a magnet that will fit down there on a bending tube and my last resort would like to be dropping the oil pan. PLEASE HELP!! thanks in advance!!
Looks like you are dropping the pan buddy worst case scenario. The funny thing is, I bet if you tried you couldn't drop that bolt down there again. **** happens, and enjoy the big green wheenie again! Semper Fi Devil.
yea i know right bro! that ******** got me again....and i was actually thinking that when i was playing with the flexible magnet that i bought (that didnt end up working) that there is no way i could TRY to drop that bolt down there again and make it happen
Yes, but that pickup is so close to the bottom of the pan, with a bolt falling from the top, I dont see how it could get under it, considering that he has the car down. However there is a sump tray in the bottom of the pan, If the bolt is on top of that tray, you wont get it out from the drain plug, will have to drop the pan, if it made it past the tray, you got a good shot of getting it.
Magnet on a string? The pick up tube is aluminum so the magnet should turn those corners alright. Go to an arts and crafts store for a large assortment of magnets. I know this is late but thought I'd throw it in here.
Location: Fairfax County, VA (You know you're here when you see the bad roads)
On the bright side your post might prevent someone else from doing the same thing. About to do my own cam swap. Best of luck...post up what you ended up doing
beat me to it.....I was thinking this too. Wonder what he ended up doing?
