Congrats To Kyle (formula383) On A New PB!
Kyle (formula383) went 10.13 @ 136 this past weekend at Temple Raceway, congrats man.
http://www.youtube.com/watch?v=ZEFaS3jPrbk
Specs are in the video description:
1995 Pontiac Formula
486/441 N/A
701/709 200 Shot
Engine & Performance
Solid Roller Forged 383 cubic-inch LT1
Wiseco Pro-Tru Forged Pistons
Callies 4-bolt Splayed Main Caps
860 Performance LT1 Intake Elbow
Edelbrock Victor Jr. Intake Manifold
AFR 210 Eliminator Competition Cylinder Heads - 2.08/1.60 Valves
Comp Hi-Tech Pro-Magnum Roller Rockers 7/16" stud, 1.7 ratio
AFR 7/16" Rocker Arm Studs
AFR Guide plates
AFR Rocker Arm Stud Girdles
Comp Cams Endurex Solid Roller Lifters
ARP Head Bolts
GM Extreme Duty Timing Set
Oversized Crank Sprocket
Ford SVO 42# Fuel Injectors
LPP Stainless Longtube Headers - Stepped 1-3/4" - 1-/7/8"
LPP Stainless Y-pipe
Magnaflow catback exhaust system
QTP 3" Electric Cutout
MSD Digital 6 Plus
Nitrous Outlet Direct Port Nitrous System - 200 shot
Nitrous Outlet Dedicated Fuel System
FJO Wide Band & Gauge
Autometer Cobalt II Fuel Pressure Gauge
Autometer Cobalt II Nitrous Pressure Gauge
Speed Inc. LT1 Accessory Relocation Bracket
Suspension & Chassis
Strange 12-way Double Adjustable Coil Overs - Front
KYB AGX 8-way Adjustable Shocks - Rear
BMR Tubular K-member
BMR T56 Crossmember with Torque Arm Relocation Bracket
BMR Adjustable Pan Hard Rod
BMR Adjustable Lower Control Arms
BMR Lower Control Arm Relocation Brackets
BMR Adjustable Torque Arm
BMR Subframe Connectors
BMR Drive Shaft Safety Loop
BMR Lower A-arms
Turn One Power Steering Pump & Pulley
Drivetrain
Built T-56 Transmission with Viper Output Shaft
Strange S60 Rear End
-- 35-spline axles
-- 4.10 gears
Strange 3" chromoly drive shaft
486/441 N/A
701/709 200 Shot
AFR Guide plates
ARP Head Bolts
MSD Digital 6 Plus
BMR Lower A-arms
Drivetrain
-- 35-spline axles
-- 4.10 gears
