Dual Caliper question
I've been tossing around the idea of getting the a dual caliper set up. Since I'm not running FI, this is more of a coolness/just for fun factor, but I'm expecting to put 700+ to the crank so I'm sure it wouldn't hurt either.
My question is how well does a setup like this run on the street as a semi-DD? I know you have to use a proportioning valve because they tend to lock up before the front breaks, but outside of that fixable issues, is there any real issues for street use? Also who makes the best kit - Strange, Mark Williams, Aerospace, or Wilwood? I'm assuming that Brembo, Bear, or SSBC don't make them since I can't find any on their website.
I also read on google that someone makes a dual caliper setup for the front, but they failed to list who. Since I can't find it, is this true?
Way overkill and in my opinion there are a lot of better things you could spend the money on! If you are N/A and don't plan on road racing or autocrossing, just get a set of good rotors/pads and some braided lines. If you really want to do a bigger upgrade do the C5 front brakes!
Thanks for the response man!
