tps
tps
I went to have my car tuned and put on dyno but my tuner said that my tps will not go full throttel or was messing up because of my aftermarket throttelbody.Have anybody had this problem.
Moderator
Could be that you need to bend your gas pedal arm to take out some
slack. Look at your idle and your WOT TPS voltages, both working the
blade by hand and by pedal. And measure the blade open position
when it's against the stop. The TPS voltage is likely a symptom of
something mechanical, it's not the end in itself, just an indicator.
