Cam out of Round? Cam gear out of round?
Old 09-26-2011, 07:31 PM
3rdCoastPowerSports's Avatar
Default Cam out of Round? Cam gear out of round?
i installed the camshaft and timing set per spec. i put a dial indicator on my camshaft gear to check for deflection. i got .008 deflection on my dial indicator. what i did was set up my dial indicator so it was touching the machined face of my new cam gear just below the cam gear teeth and chain. i rotated the cam gear 360* degrees, checking my dial indicator the whole time. in a 360* rotation i get .008 of deflection. i checked the crank gear the same way and get .001-.002 deflection (.001-.002 on crank gear is within manufacture specs). I don't think .008 is within spec. can anyone help me with this?
im not the only one who has checked my crank gear and cam gears (timing set) for deflection am I?
Old 09-26-2011, 10:45 PM
01ssreda4's Avatar
There was just a post on this within the last 2 weeks or so. OP ended replacing the timing set and the issue resolved itself. Maybe there is a bad batch floating around.
Old 09-26-2011, 11:58 PM
Havoc40's Avatar
Just for brain food. Remember you have camshaft end play, playing a factor here. As your rotating, that cam isn't staying perfectly still in the bore. Ideally you would want to start your measurements with putting the gear on a surface plate and running a dial test indicator across the machined surface, just below the gear teeth. At that point your relying on the machined "hub" being flat (or parallel depending on which way you look at it, and how you measure), so you have to analyze that as well. We're talking about runout here, not O.O.R. conditions.
Old 09-27-2011, 12:02 AM
01ssreda4's Avatar
Here ya go:
https://ls1tech.com/forums/generatio...-video-up.html
Old 09-27-2011, 12:13 AM
Originally Posted by 01ssreda4
thanks man. i checked the video out, my chain doesn't have any slack in it its tight and looks like its good,,, if i wouldn't have put the dial indicator on it to check the gear run out i would have just buttoned it up and never thought the wiser.
Old 09-27-2011, 12:15 AM
Originally Posted by Havoc40
Just for brain food. Remember you have camshaft end play, playing a factor here. As your rotating, that cam isn't staying perfectly still in the bore. Ideally you would want to start your measurements with putting the gear on a surface plate and running a dial test indicator across the machined surface, just below the gear teeth. At that point your relying on the machined "hub" being flat, so you have to analyze that as well. We're talking about runout here, not O.O.R. conditions.
does that mean im good to button her up?
does anyone else have an LS on a stand or in the car with the timing cover off and can measure your cam gear run out for me?
Old 09-27-2011, 12:49 AM
Havoc40's Avatar
I'd be buttoning her up if it was my engine. Based off your other thread anyway, .007 camshaft end play.
Old 09-27-2011, 10:57 AM
KCS
Moderator
KCS's Avatar
I wouldn't worry about it, there are a stack up of tolerances that could be playing a factor here.
Old 09-27-2011, 11:53 AM
cool, thanks guys
Quick Reply: Cam out of Round? Cam gear out of round?
