help with strange problem
Old 10-01-2011, 08:27 PM
on1wheel01's Avatar
Default help with strange problem
Ok guys 95 trans am no cats car started running rough at times. Then it will go back to normal then back again. I'm stumped I haven't had the codes ran yet but my cel is always on since no cats.
Old 10-01-2011, 08:34 PM
02ws.sik's Avatar
How does it run does it idle funny not running top shape?
Old 10-01-2011, 08:38 PM
on1wheel01's Avatar
Idle sounds ok. It's very wierd it does it everytime I drive it but goes back and forth. I'm not gonna drive it until I figure it out. Scared I may do damage
Old 10-01-2011, 08:39 PM
02ws.sik's Avatar
What goes back and forth?
Old 10-01-2011, 08:48 PM
on1wheel01's Avatar
The problem. While driving it at times its at normal performance and seems fine then it will run rough. Goes back n forth from each
Old 10-01-2011, 08:53 PM
02ws.sik's Avatar
I bet it your mass air flow. Go to autozone they will look up the codes for you
Old 10-01-2011, 08:56 PM
on1wheel01's Avatar
Can't do it on my 95. Gotta have em done at a shop. nobody around here does obd1 for free suxx.
Old 10-01-2011, 09:03 PM
02ws.sik's Avatar
I thinks its just your mass air flow i would run some fuel injector cleaner in your tank too.
Old 10-01-2011, 10:02 PM
Big Chuk's Avatar
I had a Caddy that done that. $100 MAP Manifold Air Pressure sensor fixed it right up . It was doing exactly what you are describing.
Old 10-03-2011, 10:14 AM
on1wheel01's Avatar
Ok guys had the codes ran. They didnt give me code numbers just said this. They came up
EGR valve Injector circuit, air circuit.
Any ideas?
Also I cleaned my maf and it looked pretty clean
Old 10-03-2011, 10:26 AM
on1wheel01's Avatar
Also my egr valve and such have been removed.
I also have a vac line that has been unhooked since I got the car I cant find where it would go. It's the first nipple from front connection off the intake on drivers side
Old 10-03-2011, 11:34 AM
on1wheel01's Avatar
Ok guys I figured it out. I started checking my fuel injectors and such. And I found I had a loose connection on one of my injectors. So shes good now. Thanx for all the help.
Quick Reply: help with strange problem
