lq9 ls7 or ls9 cam?
Old 10-02-2011, 01:57 PM
massillongoat's Avatar
Default lq9 ls7 or ls9 cam?
I wanna stick the stock ls7 or ls9 cam shaft in my six liter...
I seen specs early...for the ls9 211/230 555/555 on a 116 lsa
I know i know its small...but given the the split it would be a great nitrous cam which is what i'm looking for...does anyone know anyone doing this? results?
or see one for sale?
Old 10-02-2011, 05:17 PM
litle88's Avatar
I doubt you'll get anyone with results. There are better cams out there than that for some spray.
Old 10-02-2011, 06:12 PM
true but its a street car...that is daily driven in the summer....point being the cam is perfect for my set up
Old 10-02-2011, 08:36 PM
87silverbullet's Avatar
A tr224 would be a good DD cam compared to those cams.
Old 10-03-2011, 06:00 PM
Ragtop 99's Avatar
I've seen people use the C6 Z06 cam with good results on S/C cars. It will do the trick on the spray if your primary goal is more exhaust duration.
You can probably find one used for cheap.
Old 10-03-2011, 06:54 PM
litle88's Avatar
Those LPE cams are also good with like 116-118 lsa's that would make you stealthy AND VERY STREETABLE if that is what you are looking for too.
http://www.lingenfelter.com/mm5/merc...gory_Code=C379
LS1-GT11 215 / 231 .631" / .644" 1.7 ratio 118
Old 10-03-2011, 11:17 PM
whats the specs on the c6 zo6 cam? yeah that's what i'm looking for...I plan on spraying at least 100 I want it to pur like a kitten till I slam it to the floor and spray the nitrous
Old 10-03-2011, 11:20 PM
that's quite a bit of lift on the lpe cam...but that's the ball park i'm looking at split wise...any more info would be greatly appreciated thanks guys...and I've been poking around on the ls9 someone told me the pick up is in the front so i have to convert to a ls2 timing cover and timing chain and move the cam sensor to the front...truth?
Old 10-04-2011, 07:05 AM
If you have a gto you already have the ls2 front cover.
Old 10-04-2011, 08:42 AM
litle88's Avatar
^^^^TRUE^^^^
Ls9 and it's cheap W/free shipping
http://www.speedinc.com/cont.cfm?cid=C0000151
Old 10-04-2011, 10:16 AM
wrong....I have an 04 came with a standard ls1 cover...
I did a six liter swap from a truck
Old 10-05-2011, 07:05 AM
Well we didn't get those details in the beginning.
Scoggin Dickey has the ls9 cam a little cheaper but more than likely shipping will catch up to speed inc's price.
http://sdparts.com/details/gm-factor...parts/12638427
Also I can't remember if the ls9 and ls7 cams are single bolt or not. You might want to check into that.
Old 10-05-2011, 07:45 AM
bonestock_442's Avatar
Keep your eyes open for a used tr224.
Old 10-05-2011, 12:49 PM
i'm not sure....I think there 3 bolt just like ours....yeah its a lq9 from a truck....I"m gonna be running nitrous and I want it to be sleeper for sure that's why I don't want a tr224 or anyting on a low lsa..i'm looking for like a z06 cam or something along those lines
Old 10-05-2011, 09:05 PM
crankstart's Avatar
224 doesn't have much of a lope and it won't be noticed with quieter exhaust, also it loves spray!
Old 10-05-2011, 09:33 PM
mine isn't quite catless corsa....hahah
Old 10-06-2011, 07:23 AM
A TR224 on a 114 and desired idle raised to 900 rpms = No Lope
Ask me how I know
Hell, with yours being 364 cube it will eat up a TR224 more so you might not need to raise the idle.
Since the car is not on the street no more. That cam in a 3830 raceweight f-body with stock 3.23 gears and port stock heads, 3200 vig converter on a 150 shot went 10.53 @ 133.4 mph. It was a true street sleeper and made us alot of money until everbody caught on. Oh, and catless corsa.....HA. We had no lope with an open cutout
Old 10-06-2011, 12:40 PM
that set up is really close to what i have going on...I have a wet kit....it has stock 317 heads on it for now....vararam yank 3600 stall 3.46 gears..10.53 at 133??? slicks i'm assuming?>
Old 10-06-2011, 12:41 PM
i was really looking at the 02-04 z06 cam because of the split....207/218 that would be prime for nitrous
Quick Reply: lq9 ls7 or ls9 cam?
