RPM 4L60E in the 8's!!!!!!!!!
RPM does it! 4L60E in the 8's!!!!
Vid:
http://youtu.be/nv8tD_zhlAg
Full weight street car, AC and all-backed up with a 8.94, 8.96.
Vid:
Congrats again Arun. I an glad I was able to be there to experience it in person.
This transmission has been in Arun's car for quite a few years now at this power level with zero failures.
Arun uses the 2nd gear start feature that all C5 Corvettes have from the factory. His car makes so much power and is so violent out of the hole the 2nd gear start helps to tame it down so the tires can actully hook.
LOL! Shes a real full blooded 4L60e with overdrive, lock up converter and everything. Arun's car is a real deal, full fledged street car. A/C blowing cold with the radio blastin, stock seats under your butt and an air bag to punch you in the face if the worst should happen. We will eventually find a car with enough power to make a 7 second pass with a 4L60e and we won't need to chuck it in the trunk
