Popping threw exhaust and slight tap?
Old 10-07-2011, 10:40 PM
dlross's Avatar
Default Popping threw exhaust and slight tap?
I was at the drag strip and it started "missing" on the return road I hit it and itstarted popping and I could hear a tap. The car idles fine. Soon as you give it alil gas it starts popping but the tap is not always there. Please help would like to fix before hibrnation.
Old 10-08-2011, 12:21 AM
dlross's Avatar
Bump.....
Old 10-08-2011, 07:23 AM
Darkman's Avatar
I would pull the valve covers and check for damaged/broken/bent valve train components.
Old 10-09-2011, 11:42 AM
dlross's Avatar
I had running today there is no taping just popping threw the exhaust. Took it for a ride if I go wot no problem just a lower rpms.
Old 10-09-2011, 03:30 PM
JaYZeig's Avatar
had this problem on my t/a...pulled the valve covers and found pieces of a broken dual valvespring inside..
Old 10-09-2011, 05:53 PM
LilJayV10's Avatar
If it's popping out of the exhaust I would say its either a burnt/bent exhaust valve or bad/broken spring on the exhaust valve.
Old 10-09-2011, 06:09 PM
dlross's Avatar
Ok I just thought it was weird that it doesn't do it at all at wot. I will be tearing into it this week.
Old 10-09-2011, 09:09 PM
LilJayV10's Avatar
Is it throwing any codes? Can you have it scanned for miss history?
That will help narrow down. I would also do a compression test before you take it apart. If you don't won't have a starting point when you take the valve covers off. Let us know what you find.
Old 10-11-2011, 01:00 AM
dlross's Avatar
Yea I scanned it nothing in it. Soon as I get free time ill get into. Will let you guys know thanks for the help
