headache when adjusting PHB...@*^%&$
I have this problem a little bit. For me it's wayyyyy better than it was, so I just gave up and called it quits. I look forward to hearing an experts suggestion on how to measure to ensure both sides are equal.
build a "plum bob" (string with a socket ) tape it to the fender well in the center of wheel in rear, must have the weight on the tires to get a true measure from string to tire/center wheel, if need to rase to adjust PHB then lower, bounce car re measure
Johnny
Johnny
FWIW, and far from scientific....I put my fingers between the LCAs and the tires until I feel like I have the same distance, then I tighten everything up. I don't stress over an 1/16" or 1/8" difference side to side. Don't the stock axles have a little play in the stock housing anyway?
I know what you mean OP, I never did get mine adjusted to where I was happy with it. I never even thought of using a "plum bob" to help me get a measure, this is gonna save me HELLA time. I was all putting a piece of wood up to the fenderwell, leveling it out, and then measuring.
I spent probably 45min making little changes before I got it right. At that point I took a little black paint and marked the rod end/jam nut/phb on both sides so if it ever loosened I could find where I wanted things to be pretty easily.
I think I'll be doing the same!
I'm doing this right now gf in the car for weight adjustment...Aannd the bag of dog food her by herself isn't quite accurate. Glad this thread is here thx for your inputs fellas
As a suggestion, I loosen the torque arm bolts to the rear end before making adjustments. My car is very finicky about how the rear suspension is loaded/tightened. It will cause all kinds of vibes when you lay into the gas and the rear squats. Once the adjustments are completed you can re-tighten the torque arm. This prevents binding.
Hey guys.
PHB rod ends/Roto-Joints use 3/4-16 thread. Each turn yields 1/16" adjustment (1/32" each side per turn) give or take a bit for angle. It's been a long time since Trig class...
The plumb bob method is awesome as is the idea to put people and weight in there. Or half a tank of fuel.
For racing rod ends we use a similar paint method with one of those yellow paint pens.
One final thing, it's fantastic to have a perfectly centered rear suspension.
ramey
ramey
