umi shocks and springs which ones?
I need some help with buying some umi shocks and springs. I want some type of on car adjustable shocks. What type of springs for dd but also drag racing and hard turns?
I just install a set of Strano springs/Koni 4/4 shocks and a UMI PHB. Sam would be a good place to start. He also carries UMI products.
I have not had it aligned yet so I don't have much seat time. Just around the block a few times. The alignment will be done on Wednesday and then I can really get it on the road. Yes, I did Strano springs and the Koni 4/4 shocks. The 4/4's are fully adjustable on the car. I edited my previous post to make it more clear.
No. Sam advertises about 1.25" drop with his springs. All cars are different, so it varies. I will wait to measure my drop after it settles. The rear looked lower right away. The fronts are a little lower and will drop more once they get some miles on them.
LS1TECH Sponsor
If you want stock height, we'd stay on stock springs. But you'd get a huge benefit in handling with good shocks and sway bars even on stock springs (which really don't handle badly all things considered).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
