4l80 fitment issue
Old 10-10-2011, 06:32 PM
gtalq4's Avatar
Default 4l80 fitment issue
Hello. I'm trying to bolt up my 4l80 to my lq4 and when I try to tighten the bellhsousing bolts down I get it about 1/2 inch away from the block before the converter hits up against the flywheel to the point where I can't spin the converter anymore. I was told the lq4 is from 2006 and 4l80 is from 1999. If someone can help me that would be great. I'll post some pics. Oh and its an edge converter.
Old 10-10-2011, 07:10 PM
gtalq4's Avatar
http://i1224.photobucket.com/albums/ee367/gtalq4/IMAG0177.jpg
http://i1224.photobucket.com/albums/ee367/gtalq4/IMAG0180.jpg
http://i1224.photobucket.com/albums/ee367/gtalq4/IMAG0175.jpg
Old 10-10-2011, 07:12 PM
LSCustoms's Avatar
do you need the spacer and proper flexplate, or do you have the spacer, bolts and flexplate that came with your tranny?
did the original car have a 4l80 or the 4l60, if the 4l60 yo u need the proper bolts and spacer, etc
gm part numbers:
Flywheel #12621399 (used to be 12551367)
Crank Spacer #12563532
Longer Bolts #19257940 (need 6 of these)
Old 10-10-2011, 07:13 PM
gtalq4's Avatar
Old 10-10-2011, 07:14 PM
LSCustoms's Avatar
and Im not able to view your pictures
Old 10-10-2011, 07:16 PM
LSCustoms's Avatar
fixed pics for you, you forgot to put the img before and after with the brackets [i m g] and [\i m g], no spaces
Old 10-10-2011, 07:17 PM
gtalq4's Avatar
I have the Hughes spacer. have tried with or without spacer and have tried with ls1 camaro flywheel too.
LSCustoms's Avatar
i fixed for you
Old 10-10-2011, 07:20 PM
LSCustoms's Avatar
if you dont have the 4l80 flexplate, then you have to put the spacer on before the flexplate, i think and not after...
or else you need the flexplate, spacer and the 6 longer bolts
Old 10-10-2011, 07:25 PM
LSCustoms's Avatar
hopefully someone else that knows for sure about just using the spacer chimes in, cause to be safe, for my 700r, i ordered all the parts... (through gmpartsdirect was cheaper than dealer), the 700 uses the same parts as would be required to put a 4l80
Old 10-10-2011, 08:01 PM
Gingervitis Addict
slow67's Avatar
Your converter isn't seated all the way.
Old 10-10-2011, 08:04 PM
LSCustoms's Avatar
that makes sense too.. well there you have it, makes more sense then needing all the other parts, if you already have the spacer... glad you chimed in, I was just trying to help hold him over till an answer comes
Old 10-10-2011, 11:40 PM
Jake's Performance's Avatar
Looks like you are missing a chunk of bellhousing too, I hope it's not where the dowel pin locates.
Old 10-11-2011, 05:46 PM
gtalq4's Avatar
Thanks everyone for your help. Hey slow67 do you have any suggestions on getting my converter seated all the way. I spin it and push on it at the same time and feels like the input notches slide into place. How can I tell if its seated all the way?
Old 10-11-2011, 06:10 PM
cabel1's Avatar
Just keep turning, pushing , and jiggling.
Old 10-11-2011, 07:47 PM
I got a better look at your picture of the case. I hope you don't plan to run that transmission...
You are missing one of the locating dowels. The transmission is centered and indexed to the engine by those dowels, without that being there, the trans will never be perfectly aligned to the engine and you WILL see pump and converter failure.
How long it takes depends on how lucky you are with the alignment but again this is a critical alignment. I'm sure your converter guy wouldn't be too happy to know this.
It could cost you some main bearings as well.
Old 10-11-2011, 08:49 PM
gtalq4's Avatar
The Dowel on that side is in the block. If you get a close look at the pics you can see that the chunk missing is right above the dowel hole. Dowel hole still good. Thanks for the concern though.
Old 10-12-2011, 09:26 AM
FastKat's Avatar
I wound up taking out the trans, standing it up on the tailshaft (put something down like a few crumpled up towels and stand the tailshaft up on that - you're going to lose some fluid) and work the converter back and forth. You should get 3 separate "clicks" before it is totally seated. The last "click" is the toughest one to get.
Old 10-17-2011, 05:28 PM
gtalq4's Avatar
Does anyone know what the length of the converter is supposed to be from the end of the shaft to the surface were the flywheel bolts up?
Quick Reply: 4l80 fitment issue
