small-front/big-rear tires cause 'low trac' or ABS problems?
wanting to get 275-40r17 front and 275-40r18 rear for a slightly aggressive stance, but I'm afraid since the r18 tire is ~1" wider in diameter (and thusly the tires will rotate at different speeds) that this might trigger the 'low trac' light and cause my brakes to act funny. anyone who runs drag radials have any experience with this? does the 'low trac' only come on when the rears are spinning faster than the fronts? thanks ya'll.
edit: I have no TCS, if you do/don't have it please say so.
Negative on all accounts bro. I've ran 275/35/18 Nitto 555R's & 275/30/19 NT's on the rear of my 97,98, (both ran DR's) and current 2001 Camaro SS (NT's) with no issues at all. And honestly its nothing a simple tune couldn't fix, but trust me dude you'll be fine.
Thanks, that's what I'm trying to find out, did it affect your braking at all?
Also, I've been searching every LS1 related forum for days, there are no topics on this anywhere, if you can't tell I dont post much, so when I do it's something I really can't find. If you can find another thread related to this it would be appreciated.
I didnt have it tuned out, i have no TCS, or the button.. I didnt know if that made a difference. I know my rear differential is different because of it... 4 channel = TCS+ ABS. 3 channel = ABS only. The 4 channels have 2 sensors and two reluctor rings, each behind the rotor. The 3 channel has a single reluctor/sensor on the carrier inside the diff. Just thought it was a good thing to know since there is a bit of a difference. Hope this helps. Honestly, there should be a lot of guys one here running my setup, its very common. Hell, half the corvette rims on here are 17,18 combos and lots of guys run the same profile which when done so with different diameters, results in a different rolling diameter of each tire.
I think my info is correct... check me before quoting me.. lol IVE BEEN DRINKING!!!
a) having significantly larger diameter tires in the rear will trigger this system (I think we have established that it will)
b) does having TCS affect this?
c) does the system being triggered have an effect on drivability, or is it just a dummy light?
thats what Im saying, I have no TCS and I get NO LIGHT.. some that do get a light may have a different rear than you and I do...
Are you guys who get the light running a 3 channel or 4 channel rear end? I think that may be the difference.. maybe I can say that I have run this same setup on every single one of my Fbodys and Ive had 7... but none of them had TCS and I have never gotten the ABS light
so like he said, you guys who are getting the light, do you have TCS?
I get those lights the check gages is due to being low on gas lol
It only happens when I go over 60mph for longer then 2 minute. then as soon as I turn my car off, and turn it on again lights go off. And my abs is not working due to the tire differrence
I've decided to just go 17" same size all around, cheaper and won't have to deal with this. my current car is A4, and I didn't realize that even if I didn't have ABS problems that having bigger tires would make my shifting goofy. I'll just wait until I get my M6 WS6/Z06 to do this.
thanks for everyones input.
Well it seems you need to go with a smaller height tire for your larger wheel. I've never gone above 35 with any of my aftermarket wheel/tire setups, and I guess my preference paid off, my stock 17's are 275/40's so obviously no issue, but maybe that's why I have never had any issues because I like low profile tires. ABS works, no inop, when its to slick and I lose traction the low traction indicator kicks in just fine and bogs me out, my traction control still stays on with no issues and works fine, turns on and off like usual.
