FS: 1997 Camaro SS
FS: 1997 Camaro SS
Year: 1997
Make: Chevrolet
Model: Camaro
Price: $8500
Mileage: 65000
Private or Dealer Listing: Private Listing
Location (State): PA
Color: Silver
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Asking $8,500 obo
Home ported and polished heads
Ported and polished intake, Gaskets matched
Comp Cams springs, retainers and locks
1.6 Comp Cams Roller Rockers
High flow race valves
Trick flow hardened pushrods
Comp Cams CC503 cam
TRW forged pistons
New bearing throw out motor
High volume oil pump
Lunati timing chain
ATI harmonic balancer
CSI electric water pump
FLP longtubes with quick change off-road pipes and high flow cats and y-pipe
2 on the left slp exhaust
Talyor made spark plug wires
K+N air filter
Opitima yellow top deep cycle battery
Hurst line lock
NOS nitrous kit with bottle heater, purge kit and high flow bottle valve
3000 stall converter
Trans go shift kit
Trans cooler
CPT built trans (not installed)
4400 stall 9" Vigilante converter (not installed)
Lingfelter 3" alum. Driveshaft
Custom made driveshaft loop
3.73 Motive gears
Eibach lowering springs (also have stock)
Weld in sub frame connectors
Granatolli panhard bar
Kumho 275/40/17 tires (only about 600 miles on them)
ZR1 SS wheels
A set of Draglite Xp rims with a set of ET Streets and Skinnies.
Cross drilled rotors
New brakes front and rear
Polyurathan mounts motor and trans
LT1 Edit software with cable
Custom stereo box with 2 12" JL audio subs
JBL 4 ch 200 watt amp
Alpine v12 2ch amp
Sony cdx-c5000x headunit w/remote
Many more extras.
There is no warranty. Car is being sold as-is. If you have any questions please email me. Johnnyt77@verizon.net
LS1Tech Administrator
Received 1,492 Likes
Looks nice. I'd be interested in checking it out of you were closer to me. Good luck.
