Shaved and powder coated calipers and brackets for exchange program
Category: Brakes
Price: $250
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): IL
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I send you these, you bolt them on, and ship me your stock cores back.
These calipers have had a few modifications prior to coating for appearance sake. All casting lines have been removed from all 4 calipers and brackets also to smooth them. The rears have also had the raised lettering shaved off, along with the hump in the center. Makes everything look much nicer. Calipers are coated in two coats of super strength wet red and brackets have two coats of super strength wet black.
These have only 20K miles on them. We pulled them off the car ourselves on a local caliper exchange customer. Everything looks great as far as boots and seals go.
Calipers you return must be in good working order. Any repairs needed will be charged to you(torn boots/seals, metal damage, etc).
Cost for this set is $250 plus $25 flat rate shipping to lower 48. There is also a $100 refundable core charge. As soon as I recieve your stock cores back, I refund the $100 core charge instantly.
PM or call/text 847-561-4361.
They are taken, but I can easily duplicate for you in whatever colors you want for the same or similar pricing(dpending on colors).
Will do now, thanks.
