ported FAST 92, torquer V3, 1 7/8 lts... best CHEAP option for heads?
So I just picked up the Fast 92 intake set up off of TSP's race car. Ordered a torquer v3 and some TSP 1 7/8 lt's at the same time. The intake is ported to match the 95 mil tb that comes with it. Should I just go grab a set of 243's and have them ported and matched to the intake while its still off the car? Any suggestions would be awesome. Thanks in advance.
Josh
Josh
10-4. Thanks. Im really hoping to break 400 rwhp. TSP 1 7/8 Lts & ory, Borla cat back, torquer v3, 243s, ported fast, 90 mil tb, ford red tops, walbro 255, fastoys ram air, yank ss3500, performabuilt level II... sound like it will be accomplished fairly easily?
might as well get 42lb injectors as the price difference is not much and you have room to grow a little. Your tuner can adjust the flow rate...I got mine from http://fuelinjectorconnection.com/shop/ they are a sponsor here and helped me out through E-mail for my needs.
I really don't know how you wouldn't clear 400rwhp with that setup. Get a good tuner with that cam...it likes to buck like a bull at low rmps. Don't forget an 85mm MAF unless your going SD.
Josh
Josh
Save your money on the 243s....Send your existing heads to AI and have them done up nice. Also, have FIC rejet and flow-match your stock injectors to about 42 pounds.
I was thinking about picking up a set of 243s and sending them to AI when I got the $ together. I dont want my car down that long either. Surly a P&P'd set of 243's would be significantly better that P&P'd stockers... right?
I would go with AI 243s. Ive seen 243s going for under $400 on ebay. You can sell some 241s and not even have much into the used 243s. The guys at AI are quick to respond to questions and really know their ****. Some of the numbers their heads have been putting down are crazy. They certainly earned my business if I dont go FI.
