SFC Pictures....
Copy & Paste Moderator
Originally Posted by SSICK
Okay I think I got this attachment thing to work. Here are two pics hope they help.
On a side note... Is that torque arm broken?
--VIP1
the sfc's are off of ebay. they have the hole in the rear for the bolt but the front has to be welded. i'm going to weld the rear also. The torque arm is not broken it's as actually a two piece torque arm that madman made. if you look to the left side of the picture i attached below you will see a red drive shaft loop and in the middle of the loop you will see a steel colored tube. well that tube slides into the opening at the front of the torque arm so when you launch there is enough play in the suspension to help the car hook a little more.
--VIP1
Originally Posted by waterbug1999
Hey does doing the SFC's get rid of some rattling inside trhe car?
Al
