FS: PRC 215 LSX Heads with .700 lift Dual Spring Kit (Pics)!
Category: Engine - Intake/Fuel
Price: $1700
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): VA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Price $1700 shipped!!
Post here PM or e-mail cdriver71@gmail.com
Precision Race Components all new cylinder head castings completed with 215cc runners. For stock cubic inch LS1/LS2 applications.
Features:
215cc Fully CNC Ported Intake Runners
84cc Fully CNC Ported Exhaust Runners
Small Bore Chambers For Increased Horsepower & Torque+
62cc CNC Machined Chambers
2.04" Intake / 1.600" Stainless Valves
Factory Rocker Friendly!!*
The all new 215cc cylinder head is finally available for customers looking for the pinnacle of LS cathedral port performance. Now is your chance to own the same cylinder head that currently holds the fastest stock bottom end heads / cam record! The new 215cc port has been flow bench tested to flow over 320cfm & can support everything from smaller camshaft street engines all the way to all our race engines. Engine dyno testing has shown these cylinder heads support over 650 flywheel horsepower in 408cid applications.
The PRC 215 cylinder heads helped the Texas Speed 98 Camaro to run a stock bottom end record of 9.82 in the 1/4 mile!!
Flow Data:
4.00" Flow Plate - No Exhaust Pipe
LIFT INTAKE FLOW EXHAUST FLOW
.100" 68 CFM 56 CFM
.200" 145 CFM 115 CFM
.300" 214 CFM 167 CFM
.400" 271 CFM 202 CFM
.500" 304 CFM 219 CFM
.600" 318 CFM 238 CFM
.650" 321 CFM 236 CFM
*All aftermarket cylinder heads feature bronze guides. Stock rocker arms will cause increased guide wear in applications over .600" lift. Roller rockers can help to reduce this wear.
www.texas-speed.com/p-7-prc-215cc-cnc-ported-ls-cylinder-heads.aspx
Thanks
Chris
OK, yes that was confusing. I had just copied the description from Texas Speed website and the heads normally come with the Platinum Spring Kit but these heads I'm selling have the dual spring kit option good for .700 lift.
