a little extra power out of an LQ4...
Old 10-23-2011, 03:51 AM
scottymo's Avatar
Default a little extra power out of an LQ4...
I'm looking for a little extra power out of an LQ4...
I have a stock lQ4, 317 heads, 4l80e trans going in a 1965 olds 88 coupe. Looking for a little extra power and TQ. I'll be using the stock truck intake, I had in mind LT headers, cam and springs, and a computer tune. And prob a lower profile oil pan...I'm a bit of a newbie so please bear with me...My question is what cam to use? Also who makes a good low pro oil pan cause the truck one looks very deep and dont think it's going to work in the Olds...
any help is appreciated...
Old 10-23-2011, 06:59 AM
Fry_'s Avatar
don't take this as me being a jerk, but you need to spend some time lurking and using the search button. the conversions and hybrids section should help you with the oil pan question and other how do I make it fit questions. and your already in the right place to learn about cams. I can tell you for a cam in a heavy car with the stock truck intake you'll be better off with something somewhat small probably in the 220-228* range.
Old 10-23-2011, 10:10 AM
garygnu's Avatar
consider a comp cam 54-455-11,if you are using a mild stall .look at a oil pan from a ls1 .what stall converter and gears will you be using ?also look at a TSP 224r cam pkg or a tr224 cam from thunder racing.
