To all ls1tech's!!!
Or are you talking about holding the valves up while you take the springs off?
Anyway ... something around the top groove of the valve to prevent it from falling past the guide will work well IMO. Just make sure the piston is on TDC when you remove and then reinstall the new springs.
Or remove head. I know its extreme but something you can consider if needed or worried.
Alot of the guys around here use zipties for prolonged periods of time
