1999 Camaro Z28 parts
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro
Location (State): VA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I have taken the car totally apart so I might have what you need
factory springs (4)......$45
TTOPS....$75 each or $125 for the pair
Hood release cable ....$10
6 spd pedal assy.....$40
M6 crossmember....$45
ABS block w/bracket...$40
Power Brake Booster.....$20
Brake Master Cyl....$20
LS1 steering Shaft...$40
Hood Latch assy w/bracket....$20
traction control assy...$20
Door Handle Bezels....$25 for both or $15 each side
Antenna mast....$5
Air Tubes....$25 for both or $15 each side
Gas Tank Straps for plastic tank....$15
Door Mirror Brackets $15 each side
E brake handle assy....$20
Rear tail light harness....$25
PW/PL wiring harness....$20
Battery cable harness....$30
Dash Board.....$75 would like pick up only,shipping and box will be $$
Front LS1 calipers....$60 for the pair.
Rear LS1 calipers....$60 for the pair
Ls1 stock Kmember (no mounts) ....$75
LS1 spindles w/hub assy ....$30 each or $50 for both
LT1 spindles w/hubs assy...$25 each or $40 for both
Lt1 M6 trans cross member....$40
LS1 M6 trans cross member...$45
i need the driver side door switch panel. its the piece that holds the door lock buttons and the mirror switch as well as window switch. My switches are good just need the plate that clips into the door panel. pm me if you have one.
No problem I"ll give him till tommorrow to let me know then they can be yours.
