Problems with MSD Window Switch
Switch I'm referencing:
http://www.msdignition.com/Products/...ow_Switch.aspx
When first intalled, it worked. Now, there is NO GROUND SIGNAL to the yellow wire. Setting were Cyl=4, 3500-6800. In fact, there is battery voltage from that wire. Is that normal?
Which window switch would you use? Looks like I need a new one.
Guest
Posts: n/a
No thats not normal and it sounds like something with the ground circut in the box went bad.
We have had good luck with these http://www.nitrousoutlet.com/catalog...2&product=4488
Thanks. I've already installed and tested the 15974 progressive controller. I am very impressed w/the product. The little handheld is awesome, just gotta figure out the ramp setup to make it work for me.
MSD is on the way back to MSD for repair.
