00Camary
10-25-2011, 11:32 AM
I am exploring the possibility of selling my SS. This car has been a great and i cant believe i am doing this. I am firm on my price.
Best to call 314-323-5853
Car Specs:
In General:
2002 Camaro SS Convertible
Sunset Orange with Black Top
SLP Build # 504
1 of 41 SOM SS's built in 2002. Very Rare color combination
Very well optioned from SLP
Appearance Modifications:
Custom Painted Satin Black Engine Bay
Relocated Batery with Taylor Sealed Box
Whistler Mod Headlights
Custom OBD2 Innovate Gauges mounted in Center AC Vents
Custom Wideband Sensor Mounted in place of Top Switch
Deleted Side Moldings (Still Have them)
OE Concepts 17 x 9 & 17 x 11 Chrome ZR1 Wheels
Polished Calipers w Drilled and Slotted Rotors
Performance Modifications:
Shortblock
408ci Iron Block (Build Sheet available)
Dragonslayer Crank
Wiseco Pistons
Forged Rods
10.75:1 Compression
2 years and 5000 miles on new motor. Not one issue with it.
DYNO RESULTS: 550WHP
Heads
AFR Big Bore 225cc heads milled to 65cc
ARP head studs used
MLS Gaskets
Intake
Fast 90mm (Mamo personally owned this intake)
Nick Williams Throttle Body
Blackwing Intake Lid
Smooth Bellows.
Cam
Vengeance Vindicator
Exhaust
1 3/4 QTP Headers matched to QTP Y to 4" Flowmaster Merge
3" I pipe with E-Cut-out straight out before the axle
Factory Dual Dual Center Mount Exhaust
ARP Header Studs Used
Suspension
Factory Modified Springs Front and Rear
Factory Rear Shocks
KYB Adjustable Up Front
Boxed LCA's
Transmission
Untouched with 68xxx miles
Could use a rebuild
Syncro's acting up preventing downshifting into 2nd or 5th
Other than that it drives and shifts fine
Rear End
Stock 10 Bolt with Detroit Truetrac
Factory 342 Gears
Clutch
Monster Stage 3
Tick Master w/Remote Bleeder
Harlan Shift Light equipped
Pictures: More upon request
http://i491.photobucket.com/albums/rr271/AdamWhelan/SOM%20SS/DSC00028.jpg
http://i491.photobucket.com/albums/rr271/AdamWhelan/SOM%20SS/11-4-07Cruise2.jpg
http://i491.photobucket.com/albums/rr271/AdamWhelan/SOM%20SS/DSC02401.jpg
http://i491.photobucket.com/albums/rr271/AdamWhelan/SOM%20SS/62009078.jpg
http://i491.photobucket.com/albums/rr271/AdamWhelan/SOM%20SS/DSC02418.jpg
http://i491.photobucket.com/albums/rr271/AdamWhelan/SOM%20SS/62009067.jpg
http://i491.photobucket.com/albums/rr271/AdamWhelan/SOM%20SS/DSC02446.jpg
http://i491.photobucket.com/albums/rr271/AdamWhelan/SOM%20SS/62009083.jpg
Car Specs:
In General:
SLP Build # 504
Shortblock
Dragonslayer Crank
Wiseco Pistons
Forged Rods
10.75:1 Compression
Heads
ARP head studs used
MLS Gaskets
Intake
Smooth Bellows.
Cam
Exhaust
Suspension
Factory Rear Shocks
Boxed LCA's
Transmission
Could use a rebuild
Rear End
Factory 342 Gears
Clutch
Monster Stage 3
