Side exit exhaust
seabassz28, i believe onyx eventually switched to another set up due to groudn clearance issues, the same reason i did as well. i was at stock ride height as well and still coudln't get the ground clearnace id like. if you can get your hands on some squared crushed piping that would benefit you for some ground clearance. its a little easier to create ground clearance with true duals as well from what i saw when i was under the car.
good luck man
Travis
good luck man
Travis
silk98: did you guys both already sell that side-exit set-up? I'd like to try it out regardless of ground clearance. If you could direct me to a vendor, that would be cool too... Thanks!
if you want an idea on how to do it i can share that with you pm me
fyi i haven't found any vendors who actually sell it mainly i think because of the groudn clearance issues. but withsome extra time on your hands and resources to get pipes bent and what not, you can do it yourself and do it right. mine only bumped every now and then but every now and then is too much for me so i opted for lt's custom y pipe and hookercatback, but taht side exhaust had its cool factor and it sounded amazing
