Which IAT sensor for turbo setup?
Old 10-28-2011, 09:39 AM
dville_gt's Avatar
Default Which IAT sensor for turbo setup?
Looking for a good IAT, right now I am running speed density and just use a thermistor mounted in the bumper to avoid heatsoak but I do not believe this will work well for a f.i. application.
Any cheap options?
Old 10-28-2011, 09:45 AM
evo462's Avatar
The one I bought is threaded for an npt bung, its the IAT the Typhoons use...I will have to check the part number later, but I am sure someone else will be along shortly with it.
Old 10-28-2011, 09:56 AM
dville_gt's Avatar
i'd appreciate it!
Old 10-28-2011, 10:01 AM
Brad Campbell's Avatar
Delphi: 25037225
Delphi: 25036751
Delphi: 25037034
Old 10-28-2011, 12:33 PM
Avengeance's Avatar
Which are what on those 3 PNs? What are the differences? Id like to get a threaded one too.
Old 10-28-2011, 12:40 PM
Check you pm's.
Old 10-28-2011, 12:41 PM
o2camaross's Avatar
RPS sells a threaded one. That's where I'm getting mine from
Old 10-28-2011, 01:07 PM
GulfM3's Avatar
Should find them at any parts house, they are the intake temp sensor for the mid to late 90's GM 6.5L turbo diesel.
GM part number 25036751 - sensor
12102620 - pig tail
the thread is 3/8NPT, weld in bung's should be easy to find online.
Old 11-02-2011, 12:13 PM
Compressor Surge's Avatar
Got a threaded one from the junkyard, with pigtail. Mounted it in the capped off EGR hole on my truck intake. No heat soak, works perfectly.
Old 11-02-2011, 12:23 PM
oange ss's Avatar
SU107 at Vato Zone
Quick Reply: Which IAT sensor for turbo setup?
