Header gaskets and splicing O2 wires
Old 10-31-2011, 06:29 PM
borlaz28's Avatar
Default Header gaskets and splicing O2 wires
Any problems with the gaskets recieved with the pacesetter headers from TSP? What about splicing the O2 wires vs. extentions? I know extentions are best but i dont have them and will be doingthe install on wed. so that doesnt leave me much time to order either the gaskets or extentions. Also do the header bolts that come with them seal it up very well or should I try to find locking bolts?
Old 10-31-2011, 06:45 PM
85CamaroZ28's Avatar
Most people re-use their stock multi layer steel (MLS) gaskets that are on there already or buy new ones from the dealership.
Splicing O2's isn't recommended at all. They operate on such a low voltage that messing with the wires can be really tricky. There is a couple options here depending on how comfortable you are with wiring.
1) You can buy new ones from advance. Ask them for rear O2's for a 2000 vette and they will be plenty long.
2) you can re-pin the wires on the ECM so that the rear o2 harnesses will read for the fronts. There is a write up on it on here and it seems pretty easy actually I just didn't see it until after I did my headers.
Those bolts will probably be ok or you can use the stock bolts as well.
Good luck.
Old 10-31-2011, 07:05 PM
borlaz28's Avatar
Cool thanks a lot!! Do you know of any place that I can get extentions to me in a day or 2? I'll look at the write up tho.
Old 11-01-2011, 08:21 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Check the sponsors as they have everything you need. I just use Corvette Rear O2's
Old 11-01-2011, 05:14 PM
usafws6's Avatar
Depending on your location summit has extremely fast shipping
Old 11-01-2011, 05:21 PM
gregrob's Avatar
Bosch 13111 02 sensors.
Done
Old 11-01-2011, 06:42 PM
skopers3's Avatar
Whatever you do, throw the Pacesetter gaskets in teh garbage. Mine blew out in six different places in a year. They're ****.
Old 11-01-2011, 08:37 PM
usnfenix's Avatar
i did the same as you i wanted my headers in so bad i said screw it and spliced my o2. a week later my car was misfireing so bad i couldnt go above 20 and had to limp it home. (with two mustangs passing me laughing) o2 sensors were burned out. bought bosh ones and never had a problem since. 13111 and done. no extension. get fel pro gaskets or some other gaskets. in a nutshell, yes you will have to wait a little longer to put headers on if you want to do it right.
Old 11-02-2011, 03:33 AM
Carlos2sun's Avatar
Thanks for your advice!
